November 2001 Products of the Week
Nov. 5, 2001 Lightweight Dimming Ballast The Mark VII VZT-4S32 is a 0V to 10V ballast designed for the 277V operation of four F32T8, F25T8, or F17T8 lamps. It measures 1 in.x1.18 in.x16.7 in. and provides an input range of 116W to 25W. You can control it by occupancy sensors, ambient light sensors, energy management systems, and load shedding devices. Advance Transformer For more information, visit
Nov. 5, 2001
Advance Transformer
For more information, visit www.advancetransformer.com.
Nov. 12, 2001
AC Switch
This specification- and commercial-grade AC switch can be back- or side-wired and accepts 10 AWG to 14 AWG copper and copper–clad conductors. The pressure plate backwire on ground screws, auto ground clip, tri-drive terminal, and mounting screws simplify installation. An extended strap improves drywall contact, eliminating floating installations.
Pass & Seymour/Legrand
For more information, visit www.passandseymour.com.
Nov. 19, 2001
Electrical Tools
The Ridgid line of electrical tools consists of the following: No. 46E wire cutter/stripper/crimper, No. 70E coax stripper/crimper/cutter, No. 72E dual Romex cable stripper/cutter, No. 62R automatic retaining ring pliers, No. 73E wire stripper/cutter, No. 52E wire stripper/crimper/cutter, and a No. 700E 3-piece set of mini cutters/strippers/crimpers. The tools feature a corrosion-resistant, black-oxide finish; ergonomic, cushion-grip handles; and large application indicators.
Ridge Tool
For more information, visit www.ridgid.com.
Nov. 26, 2001
Hand-Held Oscilloscopes
The ScopeMeter 196C and 199C hand-held oscilloscopes feature full-color, 320 pixel X 240 pixel resolution displays and fast display update rates that immediately display signal changes, allowing users to analyze complex, modulated, and other fast-changing waveforms.
Fluke
For more information, visit www.fluke.com .
