Ecmweb 6320 Ipad Family Theft Deterrent Mobile Digital Device Mounting Systems
iPad family of theft-deterrent mobile digital device mounting systems
Feb. 26, 2014
FSR has designed a family of mounts and chargers that are compatible with iPad® mobile digital devices and meet the needs of the professional market. The goal was to design products that are aesthetically pleasing and durable while protecting the iPad® from opportunistic theft.
We have achieved this with a family of surface wall mounts, flush wall mounts and table mounts for the iPad® Air, iPad® 2 and iPad® mini. The mounts are made of steel and aluminum, look great and meet the needs of daily use.
FSR has also designed a line of patented charging solutions to compliment the iPad®. These chargers are available as stand-alone modules, keystone inserts, or as inserts in the IPS family of customizable wall plates.
SURFACE MOUNT
FSR’s surface mount for iPad® mobile digital devices is the perfect solution for existing construction and installations where surface mounting is preferable.
The enclosure mounts to a standard 2-gang electrical box. The pattern of mounting holes allows the enclosure to be mounted either centered or off-center of the electrical box as well as in either the landscape or portrait position.
The 2-gang electrical box provides a place to install the PoE to USB charger to supply power to the iPad®. The patented charger provides a full 10 watts of iPad® mobile digital device compatible power to ensure uninterrupted service.
The cover features rounded corners for safety and aesthetics and is held closed by recessed security screws deterring theft.
The cover is available in either an aluminum, white or black finish and with or without access to the Home button to support the specific needs of the installation.
The enclosure is available for the iPad®2, iPad® Air or iPad® mini mobile digital devices.
FLUSH MOUNT
The flush mount enclosure is perfect for new construction or installations where housing the iPad® within the wall is desired.
The enclosure mounts within a standard 3” or 4” wall and houses the iPad® in either the portrait or landscape position. The cover can be ordered with or without access to the Home button to support the specific needs of the installation.
The enclosure has a space to hold FSR’s patented PoE to USB charger. This charger provides a full 10 watts of iPad® compatible power to ensure uninterrupted operation. The flush mount enclosure is available in white or black finish for the iPad® 2, iPad® Air and the iPad® mini.
TABLE MOUNT
FSR’s table mount enclosures for iPad® mobile digital devices are the perfect solution for fixed installations in the boardroom, classroom, or retail applications.
The enclosures tilt 15° to 60° from vertical to ease readability from either a standing or sitting position. The enclosures can rotate 90° to support landscape and portrait positions. Optionally, the enclosure can be locked in either position if required by the needs of the installation.
The S (swivel) versions of the enclosures add the ability to swivel more than 90° left and right to support multiple users sharing a single iPad.
The enclosures can either simply sit on the table or be permanently affixed in position. Integrated cable management gives the installation a clean appearance and ensures the cables will not snag or tangle during tilt, swivel and rotate moves.
Power can be supplied to the iPad® from either the Apple® supplied charger or via FSR’s patented PoE to USB charger. The charger can be housed in the base of the enclosure for a clean appearance and supplies a full 10 watts of iPad® compatible power for uninterrupted service.
The table mount enclosures are available for the iPad® 2, iPad® Air and iPad® mini mobile digital devices and can be ordered with a white or black finish.
