Focus on Lighting Control
May 1, 2007
Digital addressable lighting interface The Square D Clipsal 2-channel digital addressable lighting interface (DALI) Gateway facilitates the ability to control DALI ballasts via a building's lighting control network. Measuring 3.4 in. 2.8 in. 2.6 in. and weighing 46 oz, the device features a DIN format for mounting in control cabinets. In addition, the unit's non-volatile memory stores operating status
The Square D Clipsal 2-channel digital addressable lighting interface (DALI) Gateway facilitates the ability to control DALI ballasts via a building's lighting control network. Measuring 3.4 in. × 2.8 in. ×2.6 in. and weighing 46 oz, the device features a DIN format for mounting in control cabinets. In addition, the unit's non-volatile memory stores operating status for seamless recovery after a power outage.
Schneider Electric
Circle 301
Lighting controller
The Miro Key Fob scene controller gives residents remote, one-touch lighting control when entering or exiting their homes. The compact, battery-operated device can be attached to a key ring or mounted on a car visor, and can activate three different lighting scenes from a range of 100 ft. In addition, the controller can be added to a Miro system using either factory default scene settings or personalized button operation. Multiple units can be set up to recall different lighting scenes. For security, it can activate a panic feature that flashes selected lights.
Watt Stopper/Legrand
Circle 302
Commercial dimmers
Titan commercial dimmers include all the parts needed to build a screwless multi-gang faceplate in the field. These incandescent dimmers offer a high-end voltage adjustment feature that allows a building manager to reduce the “at full” voltage without compromising the slider's full dimming range. In addition, the devices offer an easy-to-use labeling system with each cover plate. Other features include surge and static protection, power failure memory, slide to “off” and preset models, an air gap switch, enhanced heat management, an enclosed slider, and a matte finish. Available in 700W and 1,100W incandescent and magnetic low-voltage versions, they work with standard single-pole and 3-way wiring and switches. Colors include white, light almond, ivory, black, brown, and gray.
Pass & Seymour/Legrand
Circle 303
Lighting control package
The AuroRa wireless lighting control system includes five wall dimmers, five designer wallplate inserts, one tabletop master control, one wireless controller, and one security interface. The system's compact plug-in central antenna and/or the security interface ensure RF communication between all devices, and can be placed in a closet or under a bed. Available colors include white, ivory, almond, and light almond. For increased capability, two systems can be linked together in the same home for a total of 10 dimmers.
Lutron Electronics
Circle 304
