Sensing fibers
Steelskin plastic sensing fibers feature Dura-Bend multi-core construction that allows them to carry light through tight radius bends without signal loss or fiber damage. The fibers are protected by a braided 304 grade stainless steel over-jacket. With a minimum bend radius of 10 mm and an outside diameter of 2.9 mm, they’re designed for low-profile applications embedded in machinery. The fibers are terminated with plastic ferrules for interfacing to the company’s FP style amplifiers and can be used with most fiber optic photoelectric sensors.
Banner Engineering
For more information, visit www.bannerengineering.com.
Digital dimming systems
The Simplicity series of digital dimming systems includes wall-mounted lighting control stations that feature LCD touchscreens, pushbutton controls, and handheld infrared remote controls. Digital dimming panels contain 12 addressable outputs. Each circuit is rated at 20A and can be dimmed or switched. As few as four and as many as 12 power modules can be provided per dimming panel. Each dimming module is multi-rated to control incandescent, fluorescent, low-voltage, and neon lights, among others.
Hunt Dimming
For more information, visit www.huntdimming.com.
Insulation tester
The 61-792 Megger 5kV insulation resistance (IR) tester features hand crank and battery operation. The IR tester has a measuring range of 100K to 20Gohm, with four test voltages: 500V, 1,000V, 2,500V, and 5,000V for measuring high-power motors and electrical systems. An automatic discharge circuit eliminates the capacitive charge created by the tester immediately after test. The tester features a large analog display and a locking or non-locking test button. The button enables hands-free testing, while the non-locking button is recommended to prevent accidental or unauthorized use.
IDEAL
For more information, visit www.testandmeasurement.com.
PQ analyzer
The PNA-600 portable PQ analyzer is NEMA4/IP65 rated, so it’s sealed against moisture and dust. The laptop computer-sized analyzer is powered by a 950 MHz Celeron or PIII processor and has 256 MB of RAM on a single-board computer. The system has four voltage inputs 600V rms and four current inputs via current transducer coils. It analyzes to the 50th harmonic, and has an FTT analyzer, oscilloscope, a flicker meter, and power quality monitor. The instrument’s flat TFT display can rest on a desktop, be held in an operator’s hand, or be mounted to any surface using a threaded mount.
Dewetron
For more information, visit www.dewamerica.com.
