Code Q&A
Q. Will the AFCI breaker respond when a bedroom appliance has a locked-rotor condition, such as a window air conditioner? A. No and yes. The waveform signature of locked rotor current is not typical of an arc fault, so the AFCI will not respond. Under locked-rotor conditions, either the magnetic function or in time the thermal trip element of the protection device should open the circuit. Several
A. No and yes. The waveform signature of locked rotor current is not typical of an arc fault, so the AFCI will not respond. Under locked-rotor conditions, either the magnetic function or in time the thermal trip element of the protection device should open the circuit. Several small air-conditioning motors are equipped with a hermetically encased thermal limit device that will open before the branch circuit protection device. However, if the locked rotor current doesn’t open a protection device, the motor winding will ultimately short and the circuit breaker or fuse will open to safely clear the fault.
Q. Does a dedicated line for computer usage, marked “Computer Only” also need to be AFCI-protected? We install a separate line for computer equipment to have a stable, low-noise power supply.
A. Yes, if it’s in the bedroom.
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
The Westex Difference
Newsletter Signup
Connect With Us
