Code Calculations
Have you ever wondered if the outlet box you're planning to install is large enough? What if a box doesn't even have its capacity marked on it? The answers to those questions lie in the requirements of Art. 314. In fact, Table 314.16(A) tells you the size of the most common standard boxes and how much they can hold. The minimum box volume must allow for conductors, devices, and fittings. The volume
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Feb. 28, 2011
video
Electrical Construction and Maintenance
Arlington FBRS4200R
Arlington’s extra heavy-duty, plated steel fan/fixture box now has higher weight ratings…150 lbs for fixtures and 70 lbs for fans…when installed on joists spaced 16” on center…and 70 lbs for either a fan or fixture on joists spaced 24” on-center!...More
Newsletter Signup
Connect With Us
