Code Calculations
Have you ever wondered if the outlet box you're planning to install is large enough? What if a box doesn't even have its capacity marked on it? The answers to those questions lie in the requirements of Art. 314. In fact, Table 314.16(A) tells you the size of the most common standard boxes and how much they can hold. The minimum box volume must allow for conductors, devices, and fittings. The volume
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Feb. 28, 2011
video
Electrical Construction and Maintenance
Arlington Gangable boxes
Designed for new or retrofit applications, these snap-together gangable plastic boxes eliminate the need to construct a multiple-gang steel box out of several individual ones. Starting with a two-gang box, users can build the box they need in seconds, according to the company. For three-gangs or more, separate the box parts, add the center sections needed to make a new, larger box, and then snap the pieces back together. The UL-listed product is preset for ½-in. wall finish thicknesses....More
Newsletter Signup
Connect With Us
