Beware of Simplistic Fault Current Calculations
Specifying and
installing underrated equipment can
undermine your power distribution design
Fault current calculations are a critical piece of the electrical design/engineering puzzle for electrical distribution systems in commercial and industrial installations. A fault current calculation determines the maximum available current that will be available at a given node, or location, in the system. Once the fault currents have been calculated, you can then select overcurrent protection equipment,
Discuss this Article 2
Anonymous (not verified)
on Jun 29, 2012
My distribution is 3nos of 2000kva transformer connected with a common PCC&max capacity of the motor is 160 kw .what is the fault current level to be considered for the design .
Jeremy Kuipers (not verified)
on Oct 15, 2012
I need to calculate Fault current at my service gear. i have 42k secondary AIC at the transformer according to the power company. i am parraleling 350AL each run is 60ft. its a single phase 120/240v installation. Can you help?
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington MC Cable Connectors
One size fits several cable sizes when you use Arlington’s low cost, zinc diecast MC Cable Fittings...More
Newsletter Signup
Connect With Us
