Ecmweb 3088 Teb23
TEB23 Electrical Box Bracket
Jan. 1, 2010
The TEB23 bracket is designed to easily mount 4” or 4-11/16” electrical boxes or plaster rings in low-voltage applications
The TEB23 bracket is designed to easily mount 4” or 4-11/16” electrical boxes or plaster rings in low-voltage applications. It can be used with 2-1/2” and 3-5/8” deep studs and features two far-side supports for increased stability after installation. To benefit both the installer and pre-fabricator, the TEB23 can be mounted from any side of the bracket and features box locks to prevent boxes from separating from the bracket.
For more information
http://www.erico.com/products/TEB23.asp
ERICO
