Anatomy of a Meltdown
A catastrophic failure in a switchboard can teach us important lessons. A switchboard failure can cause immense destruction, loss of life, and extended loss of facility usage. As you conduct your predictive and preventive maintenance, this is one of the problems you should be most eager to prevent. Yet are you sure you’re doing all the right things as often as you should? Let’s look at a case history
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Feb. 28, 2011
video
Electrical Construction and Maintenance
Arlington FBRS4200R
Arlington’s extra heavy-duty, plated steel fan/fixture box now has higher weight ratings…150 lbs for fixtures and 70 lbs for fans…when installed on joists spaced 16” on center…and 70 lbs for either a fan or fixture on joists spaced 24” on-center!...More
Newsletter Signup
Connect With Us
