Building Information Modeling and Lighting Design
The pros and cons of using building information modeling (BIM) on today's digitally informed lighting designs
Discuss this Article 1
Jean-Jacques (JJ) Ahounou, PE (not verified)
on Jan 29, 2013
The future of BIM and Lighting Design will be the followings:
1) The integration of lighting calculations per room per floor, meaning clients should be able to visualize the footcandle of each room on the floor.
2) The easy replacement of lighting fixtures during Value Engineering and/or construction.
3) The integration of lighting control system into the BIM model specially for theatrical lighting systems into to efficiently provide the electrical power required without guessing the percentage utilization of fixtures & systems.
4) The provision for selectable code requirements to give more flexibility to projects and their LEED goals.
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington MC Cable Connectors
One size fits several cable sizes when you use Arlington’s low cost, zinc diecast MC Cable Fittings...More
Newsletter Signup
Connect With Us
