Sealing and Drainage Requirements for Type MI Cable
Dec. 1, 2014
Part II of Article 501 outlines the requirements for wiring systems installed in Class I, Division 1 and 2 locations.
Sealing compound shall be used in Type MI cable termination fittings to _____.
a) prevent the passage of gas or vapor
b) exclude moisture and other fluids from the cable insulation
c) limit a possible explosion
d) prevent the escape of powder
The correct answer is: b) exclude moisture and other fluids from the cable insulation
Article 501 covers the requirements for electrical and electronic equipment and wiring for all voltages in Class I, Division 1 and 2 locations. Part II of this Article outlines the requirements for wiring. As specifically noted in Sec. 501.15, "Seals in conduit and cable systems shall comply with 501.15(A) through (F). Sealing compound shall be used in Type MI cable termination fittings to exclude moisture and other fluids from the cable insulation."
Mike Holt
Strut Comparison Chart
Strut Corrosion Guide
