Minimum Conductor Size for Antennas
May 22, 2015
Antenna systems are the focus of Part II of NEC Article 810.
An outdoor wire-strung antenna conductor of a receiving station with a 75 ft span using a hard-drawn copper conductor shall not be less than _____ AWG.
a) 17
b) 14
c) 12
d) 10
The correct answer is: b) 14
Article 810 focuses on radio and television equipment. Antenna systems are the focus of Part II of this Code Article. As per Sec. 810.16(A), "Outdoor antenna conductors for receiving stations shall be of a size not less than given in Table 810.16(A)." A quick look at this table reveals a minimum copper conductor size of 14 AWG for span lengths greater than 45 ft.
Mike Holt
