The _____ of conductors used in prewired ENT manufactured assemblies shall be identified by means of a printed tag or label attached to each end of the manufactured assembly.
a) type
b) size
c) quantity
d) all of the above
The correct answer is: d) all of the above
Article 362 covers the use, installation, and construction specifications for electrical nonmetallic tubing (ENT) and associated fittings. As noted in the second paragraph of Sec. 362.120, "The type, size and quantity of conductors used in prewired manufactured assemblies shall be identified by means of a printed tag or label attached to each end of the manufactured assembly and either the carton, coil or reel. The enclosed conductors shall be marked in accordance with 310.120"
