The _____ of a DC photovoltaic source circuit or output circuit must be calculated as the sum of the rated open-circuit voltage of the series-connected photovoltaic modules multiplied by the correction factor provided in Table 690.7. a) minimum allowable ampacity of conductors b) maximum allowable ampacity of conductors c) minimum photovoltaic system voltage d) maximum photovoltaic system voltage
Website Registration Required to Access this Content
Only registered users have access to Silver content.
Registration on EC&M allows you exclusive access to high value content centered around proprietary research, expert NEC analysis and in-depth technical procedures.
Already registered? Log In here.
