Sizing Junction Boxes
Learn how to perform this task quickly and correctly - every time
The sizing requirements for pull boxes, junction boxes, handhole enclosures, and conduit bodies exist to prevent conductor insulation damage. Those requirements are in 314.28, and they apply to all conductors 4 AWG and larger (Fig. 1). To illustrate how these requirements prevent conductor insulation damage, let's consider two extremes in a straight pull situation. Suppose you have a 2-inch raceway
Discuss this Article 2
mohammad (not verified)
on Jan 28, 2013
Best explantion I have been completey confused with these calculation .thanks I wish you could explain some other complicated parts of NEC .thanks
Anonymous (not verified)
on Apr 24, 2013
What size box would I need if I have (3) 4" conduits coming in the back of the box and (3) coming out of the top of the box. Each conduit has (4) 500 MCM that will be spliced in the box. Is 36"x36"x24" adequate?
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Feb. 28, 2011
video
Electrical Construction and Maintenance
Arlington CP9000
Arlington’s new 9” diameter ceiling cover plate is the neatest way to cover unused “high hat” cans. With no tools needed, installation couldn’t be faster! CP9000’s spring anchor brackets slip between the turned down metal tabs inside the “can” or directly to the “can”....More
Newsletter Signup
Connect With Us
