Grounding with the Grounded Neutral Conductor - Part 1 of 3
Learn the NEC rules on how to use the grounded neutral conductor as an equipment-grounding conductor.Under certain conditions, you can ground all metal parts of enclosures used to install service equipment by the grounded neutral conductor on the supply side of the system. When you're using this type of grounding scheme, this includes the service weatherhead, service raceway, service meter base, and
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington CED1 Entrance Hoods
The Scoop Series CED Entrance Plates and Hoods are reversible, non-metallic, single and two-gang versions...More
Newsletter Signup
Connect With Us
