Fire Alarm System Facts
Article 760 tells us how to install wiring and equipment for fire alarm systems, including all circuits these devices control and provide power to. What it doesn't tell us is when a fire alarm system is required to be installed in the first place or where to place the alarm equipment, such as pull stations or horn/strobe units. For installation information, consult the locally adopted building code
Discuss this Article 2
Anonymous (not verified)
on Feb 6, 2013
Plant is INSTALLING a new fire alarm system. They are runing all new wires. We are in a old building (1970) 25 ft ceilings in most work areas with 10 ft on the asileways. Alarm wires are being ran along the walls on the outside of the wall with all wires exposed about 8 ft. high secured with screw mounted wire clips. Can this wire be exposed to possible damage from painting, ladders and other activites?
Vladimir (not verified)
on May 9, 2013
How many 14/2 nonplenum-rated fire alarm cables can be fit in a 2 inch EMT conduit?
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington TV Box for New Construction
Arlington’s recessed combination power and low voltage boxes – TV BOX™ and Indoor IN BOX™ – offer secure, convenient & easy way to mount LCD or plasma TVs flush against a wall...More
Newsletter Signup
Connect With Us
