Box Fill Calculations
Calculate conductor equivalents to prevent box fill violations
Box fill isn't just the number of wires in the box — it's the total volume of the conductors, devices, and fittings in a box.
Discuss this Article 4
poppop (not verified)
on Oct 9, 2012
great explanations.
Jeff Glanstein (not verified)
on Jan 23, 2013
Your statement, "You can use Table 314.16(A) only if the box contains no switches, receptacles, luminaire studs, luminaire hickeys, internal cable clamps, or equipment-grounding conductors. This is rarely the case." is misleading. The only time you will not be using any of the figures in table 314.16a is when the box is unmarked or not of the size in Table 314.16a.
jon doe (not verified)
on Apr 7, 2013
8x8x4 box, no listed volume. Is there an 80% conductor rule that applies to the allowable box fill?
Anonymous (not verified)
on May 4, 2013
What do I do if on the test it asks for two 12 AWG and four 10 AWG? It doesn't say two 12/3 or four 10/2.
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington CED1 Entrance Hoods
The Scoop Series CED Entrance Plates and Hoods are reversible, non-metallic, single and two-gang versions...More
Newsletter Signup
Connect With Us
