If the power source is a listed Class 2 transformer or listed Class 2 power supply — or it’s in listed equipment marked to identify the Class 2 power source — you’ve got a Class 2 circuit between the power source and the connected Class 2 equipment [725.2]. Take that sentence, change the 2 to 3, and you define a Class 3 circuit. Class 2 circuits are rendered safe by limiting the power supply to 100VA for circuits that operate at 30V or less, and the current to 5mA ...
Website Registration Required to Access this Content
Only registered users have access to Silver content.
Registration on EC&M allows you exclusive access to high value content centered around proprietary research, expert NEC analysis and in-depth technical procedures.
Already registered? here.
