Article 225: Outside Branch Circuits
Article 225 provides installation requirements for outside branch circuits and feeders that run on (or between) structures or poles (Fig. 1). The NEC differentiates between buildings and structures, but for convenience we'll refer to both of them as structures. Other articles also pertain to outside branch circuits (see Other Articles Related to Outside Branch Circuits on page 71); most of these are
Discuss this Article 2
Anonymous (not verified)
on Jul 25, 2012
I want to run a branch circuit from the top of a two story appartment, to a tree about 30 ft. from the building. There is a sidewalk between the two, with no entrances close by. I would like to run a messenger wire from a J-Box on the side of the building (up high, and unaccessable), to the tree. I was hoping to fasten the messenger wire to the tree, then set another Jbox on the tree, for the purpose of installing Christmas lights. The area is a low income area and vandelism is high. I want to keep the boxes off of the ground, and dont want to dig under the sidewalk. The code says you cant attach to vegitation. Is this true? Is there ANY way around this? Thanks.
on Oct 20, 2012
Interpretation help
A new construction project is divided by fire walls to create two buildings in order to comply with the building code for the construction type and occupancy. The service was designed as though it was a single building therefore multiple feeders enter one building from the other but do not run between the buildings outdoors. The design proffesionals opinion is that NEC Article 225 does not apply because the feeders are never go outside. The code authority states outside refers to outside of the building not outdoors. Which is correct? If the code authority is correct what is the rational for applying this to indoor feeders? First responders will have no idea a second building is in play and all power can be killed at the clearly identifiable service for the first building
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Apr. 15, 2013
video
Protection From Arc Flashes
Learn how arc flashes happen, how they are measured and how wearing the right flame resistant clothing can keep workers safe....More
Newsletter Signup
Connect With Us
