Full-color poster makes relay selection easier
A full-color poster is designed to simplify the selection for solid-state relay assemblies. The 22-in. by 17-in. poster includes a "Three Step Selection Guide" that enables manufacturers to quickly select the proper solid-state relay assemblies for their applications. The poster makes selection of relays as easy as choosing the mechanical configuration of the relay, then determining the line voltage,
Discuss this Article 0
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Mar. 2, 2011
video
Electrical Construction and Maintenance
Arlington TV Bridge
Arlington's TV Bridge includes two recessed power/low voltage combo boxes and all the connections you need (except for the NM cable) to install a flat screen TV in an existing wall. The best part is there's no need to run cable from a panel box - or cut holes in your framing members. Just cut two holes in the wall and access power from an existing, nearby source....More
Newsletter Signup
