EDITORS CHOICE
Mated multi-pin waterproof connectors withstand immersion These multi-pin waterproof connector systems feature a reverse taper-seal design that isolates each contact and creates a watertight seal, allowing mated connectors to be submersed in up to 3 feet of water. Heavy-duty contacts ensure reliable connections. For increased safety, the ground contact is designed to mate first and break last. DuralineCircle
Feb. 1, 2001
Circle 247 on Reader Service Card
Insulated pliers protect electricians' hands
These insulated electrician's pliers are said to withstand 10 times the standard 1,000 AC and 1,500 DC rating for ultimate protection. Extra-large finger stops guard against accidental contact with exposed metal tool parts, and the injection-molded grips provide uniform insulation thickness and dielectric integrity. Ideal Industries Inc.
Circle 248 on Reader Service Card
Transfer switch offers ease of operation
The AST3225 AutoStart Transfer (AST) system, comprised of an automatic transfer switch and engine controller, offers a dependable and economic means to transfer loads between utility-supplied power and auxiliary power systems, such as engine generators. It features ease of installation, a NEMA 3R enclosure and a microprocessor-based engine controller for automatic starting, stopping and protection of generators. Gen Systems Inc.
Circle 271 on Reader Service Card
Cable management rack is flexible
The Mighty Mo 3 cable management rack is designed for high performance copper networks. The system allows end-users to fully integrate their racking system into their cabling infrastructure at the cross-connect, as well as offering the flexibility and expansion needed for future moves, adds and changes. The rack offers three styles of vertical patch cord management: interbay with latches, traditional cable management rings and fingerduct with covers, as well as rear channel construction that protects and conceals the horizontal cabling. Ortronics Inc.
Circle 270 on Reader Service Card
Vandal-proof exit sign is as tough as nails
The Model 2040-70/77 vandal-proof exit sign features a heavy-duty angled cast aluminum frame that deflects impact and is nearly impossible to grip. The sign has no sharp corners or edges and a -inch impact-resistant polycarbonate face. Isolite Inc.
Circle 245 on Reader Service Card
Receptacle offers dead front interlocked construction
The J2BR switched receptacle now comes with a patented Sure-Lock dead front mechanism to keep the switch from being turned on unless a plug is fully inserted. The receptacle comes in 30A and 60A, 600V configurations. Keyhole mounting feet make installation easy, as does a pre-wired terminal block attached to the receptacle. Appleton
Circle 249 on Reader Service Card
