Small fixture provides big lighting
The MicroFlood (NS Series) fixture measures just 6¼ in. by 9¾ in., but provides conventional floodlighting for facades, landscaping, architectural detail and other surfaces and areas. It features easy installation. Ruud Lighting
Circle 245 on Reader Service Card
Grounding package monitors current flow
The Groundskeeper high-resistance grounding package is designed for industrial plants that want to keep a close watch on the current flowing through the neutral conductor of their low-voltage power system. Post Glover Resistors
Circle 248 on Reader Service Card
Cable simplifies two-circuit wiring with AFCI requirement
This Romex four-conductor non-metallic cable installs quickly while meeting new Code requirements. The Type NM-B 2/2/conductor cable is designed for running two circuits to bedrooms that require AFCI circuits. Southwire Co.
Circle 249 on Reader Service Card
Crimping tools mate with compression connectors
This line of manual, battery and hydraulic crimping tools will support the manufacturer's copper and aluminum compression connectors for the telecommunications, commercial and industrial markets. Nine new tools are available. They include a battery-operated die-less tool, 6.2-ton battery operated die tool, 12-ton hand ratchet crimper hand hydraulic tool, 12-ton hydraulic head, 12-ton hand hydraulic die-less tool, 15-ton hand hydraulic die-less tool, 6.2-ton die-less remote head and 6.2-ton remote hydraulic head. The lightweight tools feature improved ergonomic design and have high quality padded steel carrying cases. Ilsco
Circle 246 on Reader Service Card
Bandsaw blade line cuts all materials
This line of carbide and bimetal bandsaw blade lines features an expanded range of products that cut all materials from hardened super alloys to abrasive composites. The 3861 Sandflex NF bimetal bandsaw blade provides up to 10 times the life of ordinary milled carbon steel blades for just 40% higher cost. It upgrades carbon steel blade users to bimetal performance for greater bandsaw productivity and less downtime when sawing materials from wood to alloy steels. The blade is available in sizes from ¼- to 1-in. and pitches from three to 24 teeth-per-in. Bahco North America Inc.
Circle 247 on Reader Service Card
