Guidelines for Grounding and Bonding Telecom Systems
Updates and changes to codes and standards that affect the way you design and install telecommunications systems
Discuss this Article 2
Ernie Garza (not verified)
on Aug 6, 2012
Very good information. The use of a Ground Meggar Tester is not mention. The use of the ground meggar test set will clearly ensure that there is zero resistance or difference of potential at each ground bus bar.
Paul W. (not verified)
on Apr 3, 2013
You may wish to take a look at the Motorola R56 Standards and Guidelines for Communications Sites for another comprehensive grounding and seismic standard. It has been adopted by the DOI and all its subsidiary agencies.
I only mention it because you did not list it as a reference or resource and it is widely used at least in the land mobile radio world.
Post new comment
(optional)
White Papers
EC&M Learning Center
Webinars
Jan. 27, 2010
video
Electrical Construction and Maintenance
Arlington MC Cable Connectors
One size fits several cable sizes when you use Arlington’s low cost, zinc diecast MC Cable Fittings...More
Newsletter Signup
Connect With Us
