Advertisement
98. CBS ArcSafe: RRS-3-VB Remote Racking Device CBS ArcSafe offers a portable Remote Racking Device for the GE Magne Blast Circuit Breakers, the RRS-3MB II. This device will allow the operator to stand outside the Arc Flash Boundary while racking the GE Magne Blast Circuit Breakers. |
99. CBS ArcSafe: RRS-3-MBII Remote Racking Device CBS ArcSafe offers a single application Remote Racking Device for GE PowerVac Breakers; the RRS-3 VB. This device allows the operator to install and remove the PowerVac circuit breakers while standing up to 150 ft away with a radio remote pendant station. |
100. CBS ArcSafe: RSA 180 Remote Switch Actuator The RSA-76 Power Break II Remote Switch Actuator attaches to the front of the GE Power Break II Switchboard without the need for any modification to the switchboard. This tool allows service personnel to remotely charge, close, & trip the Power Break II circuit breaker safely from outside the arc flash hazard boundary. |
101. CBS ArcSafe: RSA 76 Remote Switch Actuator The RSA-180 Masterpact NT Remote Switch Actuator attaches to the front of the NT switchboard without the need for any modification to the switchboard. This tool allows service personnel to remotely charge, close, and trip the NT circuit breaker safely from outside the arc flash hazard boundary. |
102. Electro Static Technology: AEGIS Split Universal Mounting Kit (Split uKIT) The new AEGIS Split Universal Mounting Kit (“Split uKIT”) protects the bearings of VFD-driven motors from electrical damage and allows quick, easy retrofitting of the AEGIS grounding ring on virtually any AC motor shaft without decoupling attached equipment. Available from Electro Static Technology, the Split uKIT is ideal for HVAC service contractors and plant maintenance departments. Designed to accommodate slingers, shaft shoulders, and other end bell protrusions, the kit comes with a split AEGIS grounding ring, the halves of which are held together with a unique hinge. This hinge design allows the split ring to be opened on one side, then closed and fastened together with built-in adhesive-backed aluminum tabs, providing rigidity to the assembled ring. Ordered based on a motor’s frame size, the kit includes the correct size split AEGIS ring and mounting hardware — screws, washers, Allen wrenches, and four styles of brackets, for use in a wide range of combinations to facilitate mounting of the ring on virtually any NEMA or IEC motor faceplate. The brackets can be attached either by drilling and tapping small holes or by applying AEGIS Conductive Epoxy (sold separately). Manufacturer's suggested retail price: from $209 to $977, depending on motor size. AEGIS Split Universal Mounting Kit Product Information |
