February 2006 Products of the Week
EC&M's editor's picks for product of the week .
LED outdoor light
The 6K Series LED OutdoorArea light is designed for municipal and commercial applications. According to the company, the light’s heat dissipation enables it to have an operating range of about 50,000 hrs. Available for use in 100V, 110V, 120V, 220V, or 240V input, the series offers a selection of lumen outputs from 1,200 lm to 4,800 lm, as well as three white correlated color temperatures (CCT) and 24 custom colors. All lights in this series use the company’s patented Chip-On-Board (COB) technology.
enLux Lighting
For more information, visit www.enluxled.com.
PVC conduit repair system
This patented PVC conduit repair system is a line of couplings, adapters, and reamers designed to reduce the time and costs associated with repairing broken conduit. According to the company, this system allows PVC conduits to be repaired without having to chip away and re-pour concrete while still maintaining the inside diameter of the conduit. The steps for using this system include cutting off the broken conduit, reaming the ID of the conduit, and inserting a coupling or adapter.
Carlon, Lamson & Sessions
For more information, visit www.carlon.com.
Motor and drive troubleshooting kit
The 1587/MDT advanced motor and drive troubleshooting kit combines the company’s 1587 insulation multimeter, an i400 current clamp, and a 9040 rotary field indicator in a single case. The kit is designed for troubleshooting and preventive maintenance on motors, motor drives, cables, and switchgear. It provides insulation resistance testing up to 2 giga-ohms, with five output voltages ranging from 50V to 1,000V and can accurately measure current without breaking the circuit.
Fluke
For more information, visit www.fluke.com.
Conductive plastic enclosures
This RFI-capable version of the 1594 heavy-duty small enclosure family is molded in a metal-loaded plastic that gives attenuation levels of more than 50 dB from 100 MHz to 1,000 MHz. According to the company, the conductive plastic enclosure has EMC screening capabilities and is less susceptible to damage during assembly or normal use than a painted-on conductive layer. It has a 3-mm-thick wall and is available in five sizes, ranging from 56x56x40 mm to 167x107x65 mm.
Hammond Mfg.
For more information, visit www.hammondmfg.com.
