Ladder logic is the basis of most control functions
Ladder logic uses switch or relay contacts to implement Boolean expressions. In years past, ladder logic was made possible with discrete relays and was sometimes termed “relay logic.” Today most implementations are done using a specialized microprocessor-based device called a programmable logic controller (PLC). Although the means of implementation have changed over the years, the basic concepts remain the same.
In the case of ladder logic, logic functions are implemented by developing a ladder diagram. Named for its resemblance to a ladder, the diagram consists of two vertical rails connected by several horizontal rungs. Each rail is energized at a different voltage, and each rung contains at least one element, such as a relay coil or an indicator lamp, across which voltage can drop. In a ladder circuit, normally open (type-A) and normally closed (type-B) contacts are interconnected so as to implement the logical functions. Connecting two contacts in series implements an AND function, since the first and second contacts must both be closed to complete the circuit. Connecting the same two contacts in parallel implements a logical OR, since at least one contact must be closed to complete the circuit. An XOR implementation for two inputs, which is actually [(A AND B') OR (A' AND B)] where the prime mark indicates a logical NOT or inversion, requires a type-A and a type-B contact for both inputs.
A relay coil, whether it's a discrete device or a “virtual” device mimicked by PLC software, controls one or more sets of contacts. When a relay coil is energized or “picked up,” its type-A contacts close and its type-B contacts open. Conversely, when the coil is de-energized or “dropped out,” its contacts return to their normal state.
Other functions.
A variety of specialized input devices, such as temperature sensors, pressure switches, position indicators, and flow switches, can provide input to the ladder logic circuit. Devices like timers and counters can also be added to make more complex logic possible. Fig. 2 shows a simple motor control circuit that will only allow the motor to start — and remain running — when its lube oil pump is running, at least one valve is open, and no alarms exist. Pressing the stop button drops out the SI coil, stopping the motor. Indicator lamps — red for running, green for stopped — can also be used. This basic control circuit forms the basis for much more complex control circuits.
Related
Dreamstime M 64543493
dreamstime_xxl_45117741
