Ecmweb 3328 Southwire Power Cable Simpull Head
SIMpull Head pulling grips
Jan. 27, 2011
Southwire has applied its patented SIM Technology to medium-voltage cable. Elimination of lube results in a safer work environment, and a faster and cleaner installation
Southwire has applied its patented SIM Technology to medium-voltage cable. Elimination of lube results in a safer work environment, and a faster and cleaner installation. Cable-tray rated and available in parallels, the cable is available in sizes 2 AWG through 1,000kcmil (appropriate ground sizes also available). Southwire’s factory-installed SIMpull Head pulling grips eliminate the process of making up pulling heads, along with the risks of knife cuts and other injuries from exposed wire or scrap.
Video at: http://www.southwire.com/commercial/PodcastsAndVideos.htm
Click on "Industrial" heading and choose "SIMpull Power Cable Testimonials"
Southwire
Southwire
