Ecmweb 1836 Alumen8 Al8s 3166rtnc8bit
8-XPX high performance luminaire
Jan. 25, 2011
The 8-XPX high performance luminaire is constructed of recycled extruded aluminum for durability and corrosion resistance
The 8-XPX high performance luminaire is constructed of recycled extruded aluminum for durability and corrosion resistance. Introduced in 2010 with the new option of an LED source utilizing 4, 25W modules totaling an incredible 100W in a 2-ft housing. Extruded aluminum doorframe boasts an innovative hidden hinge system (patent pending). Full complement of mounting systems engineered to your specifications. IDA Approved.
http://www.alumen8a.com/products_xpx.html
http://www.alumen8a.com/product_documents/xpx_xcx_xwx/alumen8_xpx_productsheet.pdf
Alumen8
Alumen8
Chapter 9 of the NEC — Part 5
