Photo 312186162 © Cagkan Sayin | Dreamstime.com
question mark note
Code Q&A: NEC Requirements for Expansion Fittings
April 11, 2024
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: Expansion fittings for underground runs of direct buried PVC conduit emerging from the ground shall be provided above grade when required to compensate for _____.
a) earth settling
b) earth movement
c) frost heave
d) all of these
See answer below.
Answer: d) all of these
Section 352.44(B) of the NEC has the answer to this question. According to the Code, "Expansion fittings for underground runs of direct buried PVC conduit emerging from the ground shall be provided above grade when required to compensate for earth settling or movement, including frost heave."
Mike Holt
Chapter 9 of the NEC — Part 5
